Introduction
KPN Match API is to check and verify an identity. This API checks customer data, such as name, address and date of birth, against the same data verified by their own telecom providers. If it matches, they can complete the transaction.
API specification
Test the API on SwaggerHub
Base url
https://api-prd.kpn.com/communication/kpn/
This is the sandbox version of Match API.
Steps to Test the Match API
Below are the steps you can follow to interact with the API, ensuring it works as expected:
1. Get Access to the API
Before anything, make sure you have the necessary credentials to access the API. You need a client_id and client_secret to obtain an access token.
If you don't have these credentials yet, you might need to register on the KPN Developer portal and follow the process to get them.
2. Generate an Access Token
Use the /token endpoint to generate an access token.
This token is necessary to authenticate your requests.
Request
Method: POST
URL: https://api-prd.kpn.com/communication/kpn/match/token
Headers: Content-Type: application/x-www-form-urlencoded
client_id=your_client_id&client_secret=your_client_secret
mpm: Mobile to Person Match
Enabled Country:
Response
On success, you'll get a JSON response with an access token. Copy this token, as you'll need it for the next steps.
3. Prepare the Request for Identity Check
With your access token in hand, you can now make a request to check someone's identity.
Request
Method: POST
URL: https://api-prd.kpn.com/communication/kpn/match/insights/{msisdn}
Replace {msisdn} with the mobile number you want to verify (e.g., 31630000000).
Headers
Authorization: Bearer <your_access_token>
(Replace <your_access_token> with the token from Step 2)
Content-Type: application/json
"mpm":{
"firstname": "Hendricus Johannes",
"lastname": "van der Vorst-Boomgaard",
"address1": "237 IV",
"postal_code": "1012 SB",
"date_of_birth": "1953-11-23"
- Please note that for
address1, just the first part of the address is considered for Match and extension is not a part of it.
4. Send the Request
Once you've filled in the required details, send the request.
If everything is correct, you should receive a response with the verification results.
Response
