API menu
Number verify documentation
Number Verify - KPN API Documentation
Overview
The Number Verify - KPN API lets you verify if the mobile number provided by a user matches their SIM card. It's perfect for applications that need to confirm mobile number validity for secure logins, fraud prevention, and identity verification.
API specification
Test the API on SwaggerHub
How to Test the Number Verify API
It is advised to use Postman for testing this API, as it involves a redirect call. SwaggerHub does not handle redirect flows well. Please download the Swagger file and import it into your Postman client for best results.
Testing the /session/{session_id} endpoint:
  • Make sure that the call is made using your mobile client.
  • In Postman, disable automatic redirects to ensure the Location header is visible in the response.
  • In cURL, avoid using the --location flag.
  • Do not include the Authorization header when calling /session/{session_id}.
Please refer to swagger documentation for details.
Authentication
This API uses Bearer Token Authentication. To authenticate, you'll need to get an access token by calling the /token endpoint. Use this token in the Authorization header for all future requests except /session/{session_id}. The /session/{session_id} endpoint does not require an access token.
Example Header
Authorization: Bearer {access_token}
How to Get an Access Token
To obtain an access token, you need to call the /token endpoint with your client credentials. The token is scoped to the operations you specify in your request.
API Endpoints
1. Token Request
Endpoint: /token
Method: POST
Description: This endpoint is used to obtain an access token that is required for authenticated requests to other endpoints.
Request Body
You need to send the request body as URL-encoded parameters:
  • client_id (string): Your client ID.
  • client_secret (string): Your client secret.
  • scopes (comma-separated string): Defines the operations the token can access. Valid scopes include:
  • operator_lookup
  • device_match (for Polling)
  • device_match_notify (for Notification)
Example Requests
Polling Example
curl -X POST \ 'https://api-prd.kpn.com/communication/kpn/numberverify/token' \ -H 'Content-Type: application/x-www-form-urlencoded' \ -d 'client_id=your_client_id&client_secret=your_client_secret&scopes=operator_lookup,device_match'
  • Description: Use this request when you need to perform polling operations.
Notification Example
curl -X POST \ 'https://api-prd.kpn.com/communication/kpn/numberverify/token' \ -H 'Content-Type: application/x-www-form-urlencoded' \ -d 'client_id=your_client_id&client_secret=your_client_secret&scopes=operator_lookup,device_match_notify'
  • Description: Use this request when you need to receive notifications.
Responses
  • 200 OK: Returns an access token.
{ "access_token": "ewuriwerewrew", "token_type": "Bearer", "expires_in": 3600 }
2. Insights Request
Endpoint: /insights/{msisdn}
Method: POST
Description: This endpoint allows you to request insights based on the provided mobile number (msisdn).
Path Parameters
  • msisdn (string): The mobile number in E.164 format (e.g., 31630000001).
Request Body
The request body varies depending on the use case:
Polling
The request body can be empty if you are polling for results.
Notification
When using notifications, the request body should include the following fields:
{ "device_match_notify": { "notification_token": "abcd1234", "notification_uri": "https://your_webhook_url/" } }
  • notification_token (string): The token used as the Bearer token when posting results to notification_uri.
  • notification_uri (string): The webhook URL where the notification should be sent.
Example Requests
Polling Example
  • Description: The request body is empty for polling.
  • Description:
  • The notification_token is used as the Bearer token when posting results to notification_uri.
Please note:
To receive notifications, the session_id provided in the response must be used.
Responses
  • 200 OK: The insights request was successful.
Polling Example Response
{ "device_match": { "session_id": "IDKFA", "polling_id": "IDKFA" }, "operator_lookup": { "regionCode": "NL", "operatorName": "KPN", "mcc": null, "mnc": null } }
  • Description: Polling will only work when the /token flow has device_match in scopes. operator_lookup works in both polling and notification scenarios.
Notification Example Response
{ "device_match_notify": { "session_uri": "http://server/v1/dm/session/5f563a0bbb61c93748f773b744bf19c6" }, "operator_lookup": { "regionCode": "NL", "operatorName": "KPN", "mcc": null, "mnc": null } }
  • Description: The session_uri must be accessed to trigger the notification to the provided notification_uri.
Session Request
Endpoint: /session/{session_id}
Method: GET
Description: You can use this endpoint once you have the response from /insights/{msisdn}. This endpoint is used to initiate a session for device matching.
Invoke the session using the session ID returned from the /insights/{msisdn} endpoint, specifically under the device_match.session_id. This endpoint returns a 302 Found response with a Location header that the client must follow to continue the process.
This endpoint does not require an access token. The session ID is short-lived and single-use, and the session must be initiated directly from the mobile client over the mobile network.
Example Request
'https://api-prd.kpn.com/communication/kpn/numberverify/session/{session_id}'
Example Response
302 Found — Location header with the url will be returned.
The client must follow the Location header to continue.
Polling Request
Endpoint: /polling{polling_id}
Method: GET
Description: This endpoint is used to retrieve polling results using the polling_uri from the /insights response.
Example Request
'https://api-prd.kpn.com/communication/kpn/numberverify/polling/{polling_id}' \ -H 'Authorization: Bearer {access_token}'
Example Response
{ "msisdn": "316xxxxxxxx", "device_match": null, "remote_addr": "xx.xx.xx.xx", "user_agent": "Mozilla...", "errors": [ { "device_match": "AVAILABLE or UNAVAILABLE" } ] }
Check responses for device match status, and take further actions based on whether you're polling or waiting for notifications.
